what is a good wax , polish to use?
does any one know what product would work on a original 68 gel coat finish to remove fine scratches and not damage the original finish and shine. it is shinny right now but i would like to make it a little better. thanks for your help.
Polishing compounds can be used like the Farecla range,,,, G3,,G6,,G7 etc they will remove surface defects & light scratches on well cured paint and GRP. I have used Meguiars soft blue mold release wax on finished GRP products,,, my way of thinking is,,,, if that stuff is good enough to use on a mold,,, then it must be more than good enough to use on the things that come out of that mold. I just use that stuff because its laying around the shop,, but the stuff Mark and Paul uses sounds fine to me. Hope you gota polishing mop,,, gel-coat is rock hard,,, even small scratches take some shifting :help:
