Are 47mm carbs to big??
jr_vw2
Post by jr_vw2 »
I am building a 1915 running a engle 110 cam 1.1:1 rockers, I am running stock valve sizes but the heads are ported and polished. will 47mm carbs be too big?? should I stick with 40's?? Please help as I am about to order them and I dont want to run into problems down the road. thanks guys
47's are big for your engine, but you can also have them jetted for your flow requirements this will cost more though. I would stick with 40's for what u have as engine (stock) and then jet them for any larger engine build in the future.
UncleBob
Post by UncleBob »
47mm? Where are you gonna get those? I think dual 40's will be plenty on a 1914, especially if you're running stock valves. However, if you ever suspect a big engine might be in your future, a set of 44's could be jetted down to work.
jr_vw2
Post by jr_vw2 »
scat has a set o solex 47mm's out in the jc whitney
47's are way too big for you engine. I ran 44's for years and could never get them jetted down enough. Traded for 40's which helped . These toys run better lean for me. Eventually went to injection to cure my quest. Gene C Gadget #729
jr_vw2
Post by jr_vw2 »
Thanks for the quick responses I just ordered a set of 40mm kadrons, along with some other goodies. thanks agian
UncleBob
Post by UncleBob »
