What Duel manifols fit stock Manx2?
Posted: Sat Feb 21, 2015 6:45 am
by langan
I may have asked this before but now I do need to know I bought a motor for my new build and it has duel 48,s on long race mamifolds. I will not be back to that car for two weeks so will be thinking of what fits and not knowing. I think I need the Empi off-set style and will be down sizing to 40's. Any ideas or pictures My body is not raised or lowered just a stock pan and body..Thanks
Re: What Duel manifols fit stock Manx2?
Posted: Sat Feb 21, 2015 7:35 am
by Ed-Chenal
I don't know which body you have. I had to put a body lift in my clone to accommodate dual carbs. I used the Weber Redline Kit 40mm.
Posted: Sat Feb 21, 2015 2:37 pm
by langan
Thanks Ed but no lift for me. It is a Manx2's. There must be manifolds that fit maybe square back ones? Pictures would help.
Posted: Sun Feb 22, 2015 6:33 pm
by eurekagary
This is the answer I got from Pat Downs at CB performance.
I can use our type-3 manifold, it is extremely short. It requires the use of a bell crank style linkage instead of the cross bar type. other wise, you will need to remove the manifold/carb assembly to install the engine. Yes, I have built hundreds of engines for Manx style cars:)
Pat
I think he might know something about vw engines
Gary
Posted: Mon Feb 23, 2015 1:48 am
by Ed-Chenal
JJLangan wrote:Thanks Ed but no lift for me. It is a Manx2's. There must be manifolds that fit maybe square back ones? Pictures would help.
Since the bodies aren't the same, I don't think pictures would be of any use.
Good luck.
Posted: Wed Feb 25, 2015 7:23 pm
by langan
Ordered off-sets from CB performance and a jet pack will post results
Posted: Thu Feb 26, 2015 12:09 am
by Laxkraap
JJLangan wrote:Ordered off-sets from CB performance and a jet pack will post results
I think you'll be good to go with the offset intakes.I have them on my 4 digit manx ll and they fit.It's close on the passenger side, the upper heim joint/arm on the crossbar just misses the f'glass.And i do have to remove the air cleaners to remove the motor.I put a plastic bag over carbs to keep the bad stuff out while removing engine.
These are dual weber 40's with the offest intakes.
Laxkraap
Posted: Thu Feb 26, 2015 5:06 am
by langan
Took a chance and ordered glad to here they at least worked on yours. Hope mine work to
Posted: Fri Mar 13, 2015 3:59 am
by langan
They fit nice linkage not so much. I would like to find the cable set up?
Posted: Sat Mar 14, 2015 1:50 am
by Laxkraap
JJLangan wrote:They fit nice linkage not so much. I would like to find the cable set up?
I bought the synclink that pete offers(i dont know if i can reference another website?) but haven't had time to install yet,maybe this weekend.from what i've read,its a very smooth system.i have to do some mods to my rollbar for a sombrero top first then pull the motor for the synclink install.
If/when i install i can try to post some pics?
Sorry to hear the crossbar isn't going to work for you.it is very close on my buggy.
Tony
Posted: Sat Mar 14, 2015 4:31 am
by langan
Thanks for the lead Tony. I will cut up the bar first when I get back to that car. Hope your top goes well that in my plans too.
Posted: Wed Apr 01, 2015 3:29 am
by langan
The linkage worked out great
Posted: Sat Jan 02, 2016 3:22 pm
by Laxkraap
jjlangan...
What,where did you get that exhaust? I'm looking for something like that. Is it a headr for a 'thing'?
Tony
Posted: Sat Jan 02, 2016 4:59 pm
by langan
This one is for sale. 100% S.S. 1.5 od. tube. I made a big motor and need to make new exhaust.
Posted: Sat Jan 02, 2016 7:33 pm
by Laxkraap
PM sent
Tony
