My Australian / US Tow'dster
Post by Tom-Kathleen »
Aussi  Aussi  Aussi !!!   Tom
Oz-Towdster
Re: My Australian / US Tow'dster
Post by Oz-Towdster »
The front fenders on my Towdster starting to take shape to cover the wider stance and longer up travel . These will be strengthened up and cleaned up and then us3ed as plugg's to make a mold and make some new fenders .
And if they don't look that much different to stock Towdster guards ( thats a good thing by the way ) the definetly are as they all but cover my 6' 3" width of the front end
Oz-Towdster
Bit more done lately and some other stuff starting to get finished off .
The rear infill panel and modified Trimil Bobcat exhaust .
The front skid plate which will have a 250mm x 220mm hole cut into and ducted up to my engine oil cooler to give it good clean cool air
The modified Jamar brake and clutch pedals and Pauls custom made throttle pedal which will keep the floor clear
The centre consul with jamar X shifter
Andrew, some of the pictures have been lost in the transition to the new forum.
vincent9993
Post by vincent9993 »
manxvair wrote:Andrew, some of the pictures have been lost in the transition to the new forum.
Actually Mike, those picture links were already broken before the conversion. I think the source of the pictures may have changed. Hopefully Andrew can restore those.
Thanks Vincent, Andrew re-post those picture!
Oz-Towdster
Ok it's been a while again since the last post , but still moving forward , will let the pictures speak
Designed , cut , folded and fitted a dash panel
Mounted the oil cooler , it's a Towd , space is tight , and i didn't like the idea of the oil radiator drawing hot air off the top of the gearbox and or the hot from said radiator getting drawn into the cool air inlet on the fan shroud
Cut and folded up some headlight brackets
The alloy fuel tank in place , with the cut out area in the bottom to get around the hydralic lines of the fiddlers
MMMMMMMMMM Starting to get the final items welded out
Oz-Towdster
Pull it apart , put it together , sleep , and repeat
Yes it's back together again at the moment as Buggy Brad has been back over here in Oz among other things wiring a lot of the car for me
Dash is pretty well done although i think i'll drop the second skin around the speedhut guages , it was just an idea and the final one was to be cut out of alloy and polished
Wiring everywhere and being a towd space for items is fast running out , with the fuse box , 100 amp breaker , cig lighter , icom 440 uhf radio , (yes we can run UHF here in Aus) and the balast for the LED light bar
Switching for the following from left to right , Wipers , Horn , steering column , Interior light , LED light bar , Headlights with ignition underneath
Remote oil filter with sensor fitted to activate thermo fan on the oil cooler
And how it currently sits in full , yep theres plenty still to do , but it's getting there finally
langan
Post by langan »
Except for the steering wheel on wrong side Nicest Towd I have seen....WOW
Oz-Towdster
Anyway a bit more progress of late , thanks to my fiberglassing buddy , the plug is finally done to make the mould for my new rear fenders
PowersBuggies
Post by PowersBuggies »
Lookin Good!
Craig and Rebecca
Manx Club #3634
66 Manx/68 Towd - His
67 Tow'd/67 Manx - Hers
67 Dune Buggy - Our Build
69 Empi Imp - Korinne
2016 Goals: Rebecca - Joining the ranks of the Iron Buggy and Long Haul League
***ACCOMPLISHED!***
2015 GOAL: MOTB 2015 HERE WE COME! - With the Tow'd and the Manx!
Did you get the Subaru fitted in it yet?
Tow'd #1 (Hers)
Resorter #19-Fuscia (Hers)
Tow'd #2 (Ours)
Oz-Towdster
The rear fenders fitted up
Oz-Towdster
Front fender plugs for the moulds fitted up to check fit etc and all looks sweet
Grabed a few photos for you all while they were on
PowersBuggies
Looks like it's coming along! Bringing it MOTB with Todd this year???????
Craig and Rebecca
Manx Club #3634
***ACCOMPLISHED!***
