http://www.harborfreight.com/1000-lb-ca ... -8495.html
I realize it is only a 1000 lb lift, but I think one could be located with a little higher capacity. The things I like about this are it sits low to the ground so you could easily park over it and not waste the garage space. It is inexpensive, even at the regular price. It also seems to fit the needs of a buggy's shape and size. With a 1000 lb capacity it could be used during a build or any time the buggy is disassembled. If one could be found with a 1300-1500 lb capacity it would handle a basic buggy (OK not one of the heavyweights that some build, but a basic buggy).
I have been thinking about these as a convenient solution to the unique issues with a buggy.
Opinions?
Calvin
