'69 Update
Jon
'69 Update
Post by Jon »
ENGINE'S BACK 2270 cc Type IV aircooled Tech. EFI / DTM FRONT END'S BACK Silver powder coated 5 wide disc brakes REAR END Welding a Gene Berg mid Tranny mount and a CSS Kafer Bar brace to the horns to keep them twisting. Hope it holds ther rear end together!
Jon, Is an authentic Manx body going on that frame? If so I was wondering how the Kafer Cup brace fits. Looks like a top notch project shaping up.
Gary1719
chassis
Post by Gary1719 »
iS THAT A BERRIN CHASSIS?
Gary1719
beam
Post by Gary1719 »
what kind of beam did you go with.and what brand of injection. how do the clamps hold that beam from moving around? gary 1719# oh yeah looks good.
[QUOTE="gary1719"]iS THAT A BERRIN CHASSIS?[/QUOTE] It looks just like a Berrien chassis.
Jon
chassis
Post by Jon »
It sure is a Barrien Chassis, link pin front end and a swing axle in the rear. Front torsion bar is a Jamar setup with CB Performance 5 wide disc brakes on a 2 1/2 " dropped spindle. Removed two of the five torsion bars both top and bottom to soften the ride The frame has two clamps left and two right that bolt around the torsion tubes. The Fuel injection system is from "Simple Digital System / EM-4" link http://sdsefi.com/ Almost finished painting the frame POR 15 / PURPLE NEXT TO TACKLE THE 35 YEAR + FIBERGLAS SHELL there's a ton of info at my home page: http://users.adelphia.net./~jpboyton/
My brother couldn't believe how heavy the CB perf. rotors were so he took them to work and massaged them. He managed to remove 2 1/2 lbs. from each rotor. I think they look a little nicer too. Image What did you use to paint your calipers?
Jon
Rotors
Post by Jon »
Had them silver powder coated!
