Which steering column??
I have 3 steering columns,69,70,72, I think. Would an earlier column like mid 60s look better & fit? since I haven't seen any buggies or beetles around lately here in the land of corn & beans, I have nothing to compare. Any pics of columns in buggies? Thanks, Gary
Don Giovanoni
My 2 Cents Worth
I have used 69 bug columns twice now. Advantages: Key and high beam switch is on the column - no need to mount the key on the dash and a switch on the firewall for the high beam. Collapsable steering column is probably safer. Disadvantage: The additonal diameter of the collapsable steering column is a pain to get through the dash and firewall. I recommend the 69.
I would go with the 72 (or up). It has the windshield wiper controls on it as well as the high low beam for headlights. It is one less thing that you have to find a mounting point for on the car. Plus, it has the saftey feature of a collapsible section. Tom
Here's pics of the '66/'67 type column I'm just about to install in my new Manx (please excuse the mess!!!). Eartier columns are the same except that they don't have the small headlight dimmer switch built-in behing the turn signal switch...
I like this column as it's simple and uncluttered. I usually use a foot dimmer switch to keep the wiring easier, and I prefer a dash mounted ignition switch. Each to thier own though of course!!!
disappearing wires
Jerry, how did you install the wires inside the column so they are out of the way of the steering shaft? Any pics?
