Where can I get these??
Any VW parts house should have CV flange caps. CB most likely has them. Weddle Industries has them. I stop using them on anything that goes off road because the aftermarket axles float in the CVs and hit the flange caps causing them to leak. I make sure the area around the snap ring is clean and fill in the area between the side gear splines and edge of flange (where seal sets) with silicone. I have tried using the urethane one and they broke apart from the axles hitting them.
