Camber Stop
Camber Stop
Has anybody used one of these camber stops on a swing axle trans? Are they worth the investment?
I used one back in the late 60's on my 63 bug. It did help. If you can get some negative camber to start with, it will feel even better. The only way to get a swing axle to handle is get some negative camber and reduce the travel from there. Wide tires also help, they "tuck under" less Tom
I am running one on my Manx right now. I put it on because the wouldn't let me autocross the buggy without the camber compensator and or suspension limiter straps, because of the swing axle rear suspension. I really notice a difference in stability when driving around freeway ramps at speed. It will prevent the outboard axle from tucking under and potentially causing the buggy to roll in a hard turn.
[QUOTE="seabeeBuggy"]I found one for 130$ is there any place cheaper?[/QUOTE] http://cgi.ebay.com/ebaymotors/EMPI-9615-VW-SYNCHRO-SWING-AXLE-BUGS-CAMBER-COMPENSATOR_W0QQcmdZViewItemQQcategoryZ46104QQitemZ8023420085QQrdZ1QQsspagenameZWDVW
while I think it is a good thing on the street, offroad it would reduce the amount of "droop" the suspension would have, therefore reducing travel, not to mention it hanging down, where it reduces clearance, and its suscentible to damage. I almoust bought one the first time I took my buggy out, (offroad), but the vendor was out of stock, once I drove the buggy, I decided I didnt need it. With the low center of gravity on a buggy, compared to a bug, the swingaxles propensity for tucking under, is not as much of a problem. Of course, I am not looking for ultimate handling on the street, its pretty awsome the way it is.
I posted a couple pictures with some captions at this link http://www.manxgallery.org/gallery/Buil ... range-Manx They are the last 2 pictures (bottom of the page) I hope they help.
