Page 1 of 2
LED tail lights?
Posted: Sun Dec 18, 2005 3:52 am
Does anyone know where one can find LED tail lights that would fit a buggy? Any supplier will be a good source since Im in the idea phase of my build. Or any other tail light ideas???
Posted: Sun Dec 18, 2005 3:59 am
Might want to read this thread.
Posted: Sun Dec 18, 2005 4:04 am
I cant read it it requires a password do I have to be a member??
Posted: Sun Dec 18, 2005 4:14 am
by Reverb
Try here. Also most truck parts places carry them. http://www.led-r-us.com/
Posted: Sun Dec 18, 2005 4:33 am
[QUOTE="dirtydeedss"]I cant read it it requires a password do I have to be a member??[/QUOTE] Sorry, I guess it's in the members forum. :(
Posted: Sun Dec 18, 2005 5:15 am
Posted: Sun Dec 18, 2005 5:35 am
I tried an 1157 LED bulb that had LED's on the sides too in my stock VW tail light housing. Since each LED in the bulb is in a different location, none of them are in the fixtures designed focal point as a filiment on a standard bulb would be. As a result, the reflected light was not near as bright for the LED as for the standard bulb in the same fixture (even though the LED bulb was very bright on it's own) and thus not as attention getting. I went back with regular incandescent bulbs for the VW tail lights, and put one of the LED's into a small center third brake light not much bigger than the LED itself. :2cents:
Posted: Sun Dec 18, 2005 7:43 am
I'm plannig on buying some of these light boards for clearlaternatives.com Image And then building some light assemblies that look like this Image The clear smoky part is some lexan the blueish stuff is the light board and the rest is steel. I plan on turning in on a metal leath and then weling the tabs on then weld the whole thing to the engine cage. It sould look really good when I'm done. Or that's that plan atleast.
Posted: Sun Dec 18, 2005 12:07 pm
What about www.s-v-c.co.uk i know there in the uk but you can get them shipped. They do some cool rear lights which are made by Hella and have become quite popular over here in the uk.
Posted: Sun Dec 18, 2005 3:36 pm
by DIESELDOOG
Has anyone ordered anything from them, http://www.s-v-c.co.uk/. I have these tail lights that are in my buggy that have a crack in them and need a peplacement and they are the only ones that have it. They are the 12 light down in the more light section, ROUND REAR LIGHT 5.5" DIA Stop/Tail & Indicator "Hamburger" design.
Posted: Sun Dec 18, 2005 9:22 pm
by flaboyjim
If you are talking about the bulbs themselves, they can be purchased at most any truck stop at fair prices. E-bay has them by the dozen. Some are strictly one directional (facing rear) and others have wrap around leds for about 120 degree illumination and visibility. I purchased LED 39 Ford lights (24 leds) mounted on a pc board for the rear of my buggy. With these, if you purchase a stainless bezel with them, all you need is a piece of cut to fit rubber insullation, a piece of stainless sheet and tin snips. The only hole to make is the one for wires and the two hold down screws. The only drawback to the original 39 ford taillight assembly was that it took a 2 inch by 3 inch hole to accomidate the housing. Modern stuff makes it really easy on us build by the seat of your pants guys.... :rock:
Posted: Mon Dec 19, 2005 3:10 am
I need to hook up my buggy a tail light fixtures that includes stop turn and reverse in eaxh fixture! Are these being made or do I have to go with two turn, stop fixtures and two separate whites for reverse ???
Posted: Mon Dec 19, 2005 5:00 am
I think you can get ones that have stop, turn, and blinker all in one light but i think you will need to have a separate light for reverse.
Posted: Tue Dec 20, 2005 5:57 am
Ok Ill go with sepparate stop/turn an reverse lights but... Does anyone make stop/turn lights that have clear lens or other color than red? thanks! and sorry for the other LED lights thread,,,stick to this one!
Posted: Tue Dec 20, 2005 6:07 am
I know that they have the 4 inch round led tail lights that glow red at princess auto. http://www.princessauto.com/PAcountry.cfm?CTRY=CAN&INF=home
