Roll Cage / Rear Bumper - REVISTED
I was just going through the pictures that I took at Bug-In last March. I came across this roll cage with integrated bumper. It looks do-able on a short WB buggy - anyone see any drawbacks to this?
FLABOYJIM, about the only comment I have doesn't relate to the structure. I don't see an easy way to put a top over it without creating a lot of space for water to come in. I guess in So. Cal that's probably not an issue, but for us on the coast of the east coast, it could rain any minute.
Every frame I build has a rear cage, Most of the time I'll use the two bolt exhaust flanges for a joint. The three bolt look nicer, but cost 3x as much as a two bolt. There is another why of making a joint but that the a pic tell a 1000 words deal. I don't have a pic. That yellow buggy. the engine cage it's self is the std store bought cage. if you look about where the muffler tip is then go over to the front pulley. You will see a fine line on the black down tube. Thats the upper joint, the rest of the mount are in the std places. The cage on this yellow car to me (2 cents) is a show cage. It's built to sell as 90% of the cage's are. What I mean is it's built as cheap as possible, Production cage. I see to many guys pay too much for a cage. Not these but others. also in two case's I know of. Guy pays 1200 for cage, cage looks great up above the body a real show piece. Both got in side inpact roll overs. both cars (not at the same time) the upper cage still was in good shape, but be low the fiberglass, They had no bracing other than the four tubes mounted to the floor pan. The cages where push over at about 45 degrees, In other words bent to hell. The lower section did nothing for safety. Yes I have a real attiude about some of the cage's being marketed today. They are not safe. Sorry about the rant
I agree. From personal experience of how unsafe a buggy is in an impact I would also stress the fact of having a properly built cage is a must. If your looking for some good ideas find a local company that builds cages for baja's rock crawlers, or just a plain old fabrication shop. They should be able to help you a great deal on what to do and what not to do. It is a very good idea to have both your engine cage and your front bumper tied into your normal cage. It makes the whole car much stronger and will be able to take more of a beating. Plus it just looks a lot cooler.
