1977 type 3 fuel inj. help please
Posted: Sun Nov 27, 2005 11:18 pm
I know this is off topic for this forum but I have found more heplfup people on this site thatn anywhere else. I bought a 77 bus w/ type 3 engine. starts with starting fluid but soon stalls. I have a Haynes book on the bus but it says fuel injection work is best left to professionals with Bosh testers... Anyone have ANY info that might help? where might I find the correct testers?
Posted: Mon Nov 28, 2005 1:26 am
The Bentley manuals have an extensive section on troubleshooting the fuel injection. If you do a search online you will see there are quite a few websites for troubleshooting VW FI.
What is the problem?
Posted: Mon Nov 28, 2005 1:55 am
by tpinthepack
I just finished a complete F.I. renew on my 1979 super beetle with fuel injection. IT is really easy. I used the Bently book. My car would not run, I followed the trouble shooting procedures. Checking the double relay, fuel pressure and all injectors. I ended up having plugged injectors, and a bad fuel pump. I replaced all hoses, and cleaned the tank well. It runs awesome.
Posted: Tue Nov 29, 2005 10:20 pm
Thanks guys. I picked up the bently book this afternoon. ( Gonna throw the Haynes book in the trash...) I havent checked it out yet but I am sure the info is in there i need....:laugh1:
Posted: Tue Nov 29, 2005 11:54 pm
by Lee
Here's a good online source for all things VW Bus:
http://type2.com/ Go to the "Library", select "Fuel" and scroll down to "Fuel Injection". You will find a couple of items that may interest you.
Bug and Bus are different
Posted: Sat Dec 03, 2005 12:28 am
by ericrb76
Bug and Bus fuel injection are different. A 1977 bus has a type 4 motor, a type 3 is almost the same as a beetle. One injection system is called L-jet the other J-jet, not sure which is which. On a bug all four injectors fire at the same time, on a bus they fire one at a time. Vacum leak- these set ups will not run with a vac leak. Disconnet the plug to the mass air flow senor, try and start the van with it unplugged. if the van starts then you have a vacum leak Double Relay- this thing always goes bad, it is what switches the power from the computer and fuel pump when the ignition is in the "start" or "run" position. Fuel Pump - Have someone try to start the van and place your hand on the fuel pump, does it run? Do you have pressure in the FI loop? If the fuel pump does not run this could either be the fuel pump itself or the double relay. Peace
Posted: Sat Dec 03, 2005 12:32 am
Thanks Eric.
really doubt
Posted: Sun Dec 04, 2005 2:23 pm
by tpinthepack
type 3. would be a type 4 new. not easy to convert to a type 3. would be much less power
