Front Bearing ?
Posted: Sun Oct 02, 2005 6:39 pm
Hello All, I am replacing the front wheel bearings. I used my power washer to remove all the grease from the cavity between the inner and out bearings. Should I refill this cavity with grease or just pack the new bearings and re-install? Thank you, Trent
Posted: Sun Oct 02, 2005 7:21 pm
Repack and install would be my advice. That "extra" grease doesn't help any as far as I know.
Posted: Sun Oct 02, 2005 9:40 pm
Why use a powerwasher? When I did my rebuild I simply wiped out the cavity with paper towels and then sprayed with brake cleaner. wiped out again and repacked the bearings.
