Engine ID and Carb info ?
towd-dude
Post by towd-dude »
[FONT=Comic Sans MS][FONT=Comic Sans MS]My recently purchased Burro has an engine number that I can?t identify. Can anyone help? The only book I have is a 2009 Empi parts manual and this engine number is not listed under any model. The number is stamped on the case half facing the case seam (left of the generator stand, not below facing aft. 00347972 there are no letters. The transmission is a RGB out of an early bus. Perhaps the engine came with it ???? Also, it has the tinest carburetor I have ever seen. It has a round float bowl that says Bocar 30-Pict ? 1. Anyone know anything about it ? [/FONT][/FONT]
Post by manxdavid »
Are you sure the first figure is a 0 and not D? If it's a D that would make it a 1200cc motor which could indeed have been from an early Bus. This is a useful table... http://www.partsemporium.co.uk/EngineCodes.htm
rhuyssen
Post by rhuyssen »
Engine cases with the ID number in that location were mostly from Type 3 cars. These could be used be used with the sheetmetal for an upright Type 1 installation. A lot of the cases were interchangeable and it is hard to tell what it is without taking it apart. A lot of different sizes look the same from the outside. The Bocar carb is an aftermarket replacement. Hope this helps. Richard
towd-dude
Post by towd-dude »
[FONT=Comic Sans MS]David,[/FONT] [FONT=Comic Sans MS]No letter, just 00 then the numbers.[/FONT] [FONT=Comic Sans MS][/FONT] [FONT=Comic Sans MS]Richard, [/FONT] [FONT=Comic Sans MS]Thanks for the info in the carb.[/FONT] [FONT=Comic Sans MS][/FONT] [FONT=Comic Sans MS]Bob[/FONT]
towd-dude
Post by towd-dude »
[FONT=Comic Sans MS]David,[/FONT] [FONT=Comic Sans MS]What does "ohne" mean? Thanks for the table, I'll save it.[/FONT] [FONT=Comic Sans MS][/FONT] [FONT=Comic Sans MS]Bob[/FONT]
Post by manxdavid »
No idea on 'ohne' I'm afraid. Is the engine single or dual port? I suspect the only way to tell for sure what it is will be to take a cylinder head off and measure the bore and stroke. With the engine # in a wierd place it could've started life as an industrial spec. engine or something similar.
towd-dude
Mystery Solved ! ! !
Post by towd-dude »
[FONT=Comic Sans MS][FONT=Comic Sans MS] The first number is not a number but the letter "U" (remove some more dirt). According to the 2009 Impi parts manual the engine is a Type III built between 8/69 and 7/70. Thanks for your help you pointed me in the right direction. Thanks again, Bob [/FONT][/FONT]
Post by manxdavid »
[QUOTE="Towd Dude;15573"][FONT=Comic Sans MS][FONT=Comic Sans MS] The first number is not a number but the letter "U" (remove some more dirt). According to the 2009 Impi parts manual the engine is a Type III built between 8/69 and 7/70. Thanks for your help you pointed me in the right direction. Thanks again, Bob [/FONT][/FONT][/QUOTE] That figures with the number being in that place. It'll be a 1600 dual port then, a good motor but if running with upright tinware it should probably have a 34pict 3 carburettor fitted, or better still duals... There are some other useful tables on this site... http://www.partsemporium.co.uk/
jsturtlebuggy
Post by jsturtlebuggy »
Bob, Glad to hear you found the whole number on the case. Is this engine going to mark its spot along the trail? Does it have single port or dual port heads? The 30PICT carb will work well for low speed cow trailing. More bottom end torque with it then something bigger. I don't think you really want to go real fast in a short wheel base burro with reduction box gearing.
towd-dude
Post by towd-dude »
[FONT=Comic Sans MS]Joe,[/FONT] [FONT=Comic Sans MS]It's a dual port. Not sure how fresh it is but seems to run strong and does not smoke. Believe it or not it does not have a case of the drips... yet. I did get it up to 50mph once and it didn't seem to be working to hard. I would have pushed it harder but I didn't have a windshield at the time and I was freezing! In general I think it will work well for "Cow Trailing".[/FONT] [FONT=Comic Sans MS]As for the Manx, it got a new roll cage (not powder coated yet), new seat covers, bumpers and I want to add a tach.[/FONT] [FONT=Comic Sans MS]See you in 21 days. [/FONT] [FONT=Comic Sans MS]Bob[/FONT]
