Adjusters
Chicago Joe
Gary, I think you need to remove the front beam and completely disassemble it. Then cut out the center grub screw section and have the new sway away adjuster welded into the correct position on both the upper & lower tubes. Once welded you then reassemble the front beam and replace it on the vehicle. I also remember hearing that it is a very messy, greasy, & dirty job. Not a lot of fun.
Joe Spittler - 1118
You want to have the beam disassembled and all of the grease cleaned out of it so it doesn't interfer with your welding. Scribe horizontal lines at the center of the existing grub screw holes for reference before cutting the center section out of the beam. As said before, only do one beam at a time. Use the scribe line to locate the new adjuster. If you want both up and down adjustment, rotate the adjuster so that the center of travel is on the scribe line. If you can cut and weld, it is not a difficult job.
I haven't used them yet, but Avis Adjusters don't require cutting the beam apart. http://www.appletreeauto.com/avis-adjus ... -1580.html "AVIS ADJUSTERS ARE A SIMPLE WAY TO MAKE YOUR BEAM ADJUSTABLE. SIMPLY INSTALL THE CENTER ADJUSTER IN THE BEAM AND OBLONGATE YOUR EXISTING GRUB SCREW HOLE. WELD ON THE ADJUSTER PLATE TO THE BEAM. PROVIDES A QUICK AND EASY WAY TO ADJUST YOUR RIDE HIEGHT."
[QUOTE="manxrob;15059"]I haven't used them yet, but Avis Adjusters don't require cutting the beam apart. http://www.appletreeauto.com/avis-adjus ... -1580.html "AVIS ADJUSTERS ARE A SIMPLE WAY TO MAKE YOUR BEAM ADJUSTABLE. SIMPLY INSTALL THE CENTER ADJUSTER IN THE BEAM AND OBLONGATE YOUR EXISTING GRUB SCREW HOLE. WELD ON THE ADJUSTER PLATE TO THE BEAM. PROVIDES A QUICK AND EASY WAY TO ADJUST YOUR RIDE HIEGHT."[/QUOTE] How do you get the old center piece out of the old beam and the new center adjuster in place on Avis adjusters? Without a milling machine I guess the best way to slot the grub screw hole would be chain drilling and grinding? Is 'OBLONGATE' a real word in the US?
With the Avis style adjusters you use the original stock center piece. You are correct David, drill two holes and grind in between (oblongate works for me). But first you have to drill and grind out the dimple on the beam at the back of the center section so that it will rotate. This also allows you to slide the center section out of the way while you make the slotted (oblongated) hole. Avis adjusters work better for lowering than raising, because it is dificult to put much preload on the Avis style without the adjusting bolt like the Sway-A-Way style.
I've never been a great fan of Sway a ways, always having prefered to just cut and turn the center mounts and weld them solid. On a Bug 1/2" turn on each tube gave an even 4" drop. I like the look of the Avis ones though as they don't take too much of the original strength out of the beam.
I managed to get something done today Adjusters in and spot welds tig welded up just have to grind smooth. I thought you guys could use some pictures. Gary 1719#
