Less than $100 check this out !!!
One Modification needed. The Size of the eyelet on the adapter is 3/8" - the threaded barrel on the Marinco wiper is 7/16" - I used a 3/8" sharp/new drill bit and slowly made the 3/8" hole to exactly the size where it actually fit in a threaded manner over the barrel. Once done, screwed the adapter 10mm directly into the MANX mirror mount which is also 10mm with loctite - its very stable. adjusted the manual arm to work closely next to the mirror side. Its out of the way, very stable, and looks great. The Marinco wiper is a little more expensive than the cheaper ones you can buy, however, most of the parts are stainless (specific boat manufacturer) - see below final assembly and installation:
