Transaxle
nroadrunner
Transaxle
Post by nroadrunner »
Joseph or however When you have a 1958 pan and want to put a 1968 transaxle in it there are two ways to go about it. Weld in a new front mount or put a new nose cone on the tranie. I can not remember the number of the nose cone I know it ends with a 11 Help Nate
You will need to use a Bus nosecone and hockey stick to make it work with a rubber mount. Part # starts with a 211 Used on 1961 to 1967 bus. Most of the time hockey stick will have to be drilled for the set screw on the coupler since on a bus it is on the bottom.
nroadrunner
transaxle
Thanks Joseph I knew you would know. Nate
