[QUOTE="Mvovr"]I still have drums all the way around but I do like the weight transfer. At times now it feels like I need two feet to stop.
I was actually thinking about staying with the coil overs in the rear simply because there is usually 4 in my buggy. Wife and 2 kids. and Unfortunatly I am no featherweight!!
Mel do the discs in the front soften the brake pedel?[/QUOTE] Ive tried swapping wheel cylinders around to get the break balance right,,, but when i did the suspension thing it all seemed to work well,,,,,,,,,,,,,,,, before it would just lock up the fronts and skid ,,,,,,,,,, now under breaking it lifts the rear, throwing more weight up front , sort of digs in. If you need two feet to stop it could be the flexi break pipes collapsing,,or wheel cylinders problem,,cheap to fix and renew the lot,, drum brakes are fine if set up right, discs are just simple and fast to change pads, and dont need adjusting,,, as for rear coil overs why not try air shocks??
