Engine Tin--What's Required
papya
Post by papya »
What pieces of engine cooling tin can I do away with on my Manxter?
Obviously the curved rear piece is not required. What about the front piece that goes between the case and the body?
Also what about the down piece from the doghouse cooler?
Left and right under cylinder rear deflectors?
The wife says "He works on cars, it's cheaper than other women and she knows where I am at night"
GotManx
Re: Engine Tin--What's Required
Post by GotManx »
I usually just run the shroud and the cylinder tins. Make sure the deflector tins under the cylinders, above the pushrod tubes, are in place.
papya
Post by papya »
GotManx wrote:I usually just run the shroud and the cylinder tins. Make sure the deflector tins under the cylinders, above the pushrod tubes, are in place.
Thank you.
