Drum Front Disc Rear Setup
Posted: Sat Jan 12, 2019 5:31 pm
by DesertWRX
I’m looking for the correct master cylinder for this setup. I’ve hear that the stock single piston master works and the newer dual piston master’s work too. Does anyone here have experience with this?
Re: Drum Front Disc Rear Setup
Posted: Mon Jan 14, 2019 3:42 am
Yes you can use either the single or dual master cylinder with that combo. I prefer the dual circuit master cylinder so if something happens you still will have some braking action.
One thing you may want to think about installing is a proportioning valve. That way you can adjust the brake bias. I would install it in front circuit because there is a chance of the front brakes locking up.
With the proportioning valve you can reduce the amount of fluid reaching the front disc to keep them from locking up.
Get one that is adjustable, so you can change the setting with different driving conditions.
Posted: Mon Jan 14, 2019 9:18 pm
by DesertWRX
jsturtlebuggy wrote:Yes you can use either the single or dual master cylinder with that combo. I prefer the dual circuit master cylinder so if something happens you still will have some braking action.
Sure familiar with a proportioning valve. Had one on our Mazda RX3 SCCA car to cut back the fronts.
Posted: Mon Jan 14, 2019 10:18 pm
by Tom-Kathleen
If you are going to use a proportioning valve, here is one with VW type fitting capability. No adaptors.
https://www.pegasusautoracing.com/produ ... ecID=10257 Tom
