It is currently Sat Feb 24, 2018 1:15 pm
Post new topic Reply to topic  [ 1 post ]
Author Message
 Post subject: the 3 inch body lift
PostPosted: Tue Aug 09, 2016 9:48 pm
Offline
Images: 55
if your building your buggy for off road use consider the 3 inch body lift. it will give great ground clearance by allowing large diameter tires. I use 15 inch rims front tire is a p225/75 R radial tire4331 body clearance is fine and never rubs. the rear is a 33x10.5 tire 15 inch rim using a swing axle trans4330 the body never rubs even fully loaded with equipment off road. the body ground clearance is 12 inches in front 4337 13 inches rear the suspension is stock no adjusters. an added benefit is easy access to your tyrods steer box brake master cly. and bottom gas tank hose. same in rear easy access to adjust clutch and engine needs.4350
Top
 Profile Personal album
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
