This is what happens on a 15 year build. I have an ATE master cylinder with a Volvo reservoir. I installed this a long time ago 10 years plus. Never filled the system till today. Front brakes fluid flowed fine, but the rears look like they are clogged, I will pull it off tomorrow. Should I just order a new MC or try to repair this. I am sure the wheel cylinder are the same so should I replace them too? I see AC industries thru SoCal imports, sell MC with reservoir, anyone try or using these. Price is cheap. I know brakes are pretty important.
I guess I should have filled the system way back then
Gary and Annie Dam
Dual master cylinder ?
Re: Dual master cylinder ?
What are you all using for your dual master cylinder and wheel cylinder? Anyone using AC industries from SoCal imports?
Gary and Annie Dam
Gary and Annie Dam
My experience with master cylinder sold by So Cal is I bought one and it sat on the shelf for a couple of years before I needed to use it. It had a bad circuit in it and it was to long of time period to return it. Some times the cheapest is not always the best.
We are using a dual master cylinder from A C Industries on a 4 wheel disk brake kit on our '68 Manx ('62 chassis) and it is working fine. However, it is the 1st one I have ever put on that should have been "bench bleed". I ended up having to crack the outlet lines to get the air out of it and get the system working. Tom
Thanks guys, Do you think since the whole brake system was never filled that it's dried out and I should replace the all the hardware? I noticed the the rear chamber of the master reservoir won't suck down. The front looks like it's fine. Maybe I have the same issue you had Tom. I need to play with it some more.
Thanks again
Gary and Annie
Thanks again
Gary and Annie
