Wreckers 8" Beam Fit & Roll Cage
Old-Towd
Post by Old-Towd »
Front Bumper almost done -
Started the rear Bumper today -
1969 Sand Rover T pickup
1973 Thing / Yorba Linda,Ca.
Old-Towd
Post by Old-Towd »
Buddy Andy (  Pre-Fab & Welder Dude )  and me working on my fuel tank support -
Left a flange at each end for blinker and head light support -
Old-Towd
Post by Old-Towd »
Pushed so hard to take Wrecker to it's 1st run Manx Club Big Bear Run that a lot of things got over looked even though I made a list to recheck stuff. Plus if it wasn't for a bunch of Buggy Buddy's help like Jon of Top Line , Super Ed , Kevin , Lee , Bill , Christy, some nights we even worked to midnight, Super Buddy's.
Been fighting the shifter the whole time but lately it stopped me from driving Wrecker I figured it was the the short shift rod with 10 degree angle that I couldn't get right. I checked the shifter, it looked good springs and all.  Ed stopped by and we pulled the shift rod to start all over and discovered that every time we locked the shift rod nut the vice grips were collapsing the shift rod. That was not our problem.   We realized the shift rod bushing must have shifted and was loose causing play , brand new bushing from Ed and we reassembled the shift rod.  The hockey stick dimple from the transaxle needs to be at 12 o'clock for the shifter neutral and at the shifter end the shift rod bucket needs to be centered in the mount hole. It shifts like a new car now, thanks for your help Ed.
I plan on altering the shift rod with a steel rod insert that will allow me to put an open end wrench on it so when I tighten the lock nut I will have something to hold it by.  We're having fun now.
Old-Towd
Post by Old-Towd »
It's about time to install turn signals, looked at about ever light on the market?nothing made me happy. So I decided ?to play with my mine and this is what I came up with -
I made a divider so the light would not bleed over -
Then I drilled a hole for a pop in light -
phpBB [video]
1856
Post by 1856 »
Very trick ...
Mark
Old-Towd
Post by Old-Towd »
Thanks Mark, did a up grade on the tail lights figured the high extreme speeds I'll be doing that the blinker light might pop out so I made a lock-in bracket. That's my story and I'm sticking to it.
Old-Towd
Post by Old-Towd »
Next thing on the list, engine cover don't ask why but it's a roll cage suspended engine cover that bolts in.
With help from Skidmark ( Steve ) we acquired the aluminum for my engine cover and skidplate , thanks Steve -
Need to re-drill the front engine cover plate holes , some how my measurements were off -
Finally plugged the original fuel inlet hole in the hood -
I used the second fuel hole plug to repair the first one -
Man it's starting to look like a real Buggy -
It looks small next to Skidmarks Baja at Top Lines Open House -
Old-Towd
Post by Old-Towd »
Fiberglass the underside is easy compared to the outside ( paint side )  my driver side head light mount is showing it's age and has a crack making the head light lean a little , it should have been fixed when the body was off and upside down . So I was playing with the Kitty Hair I bought and found out it does not spread like Bondo it globs on for filling deep cracks so I tried it on my head light mount.
I think it turned out ok just need to road test it.
Nice job. Where did you pick up the kitty hair?
Post by Tom-Kathleen »
Nice job.  But I think a larger washer under the base of the headlight and a support from the front suspension will help in the long run.  Tom
Old-Towd
Post by Old-Towd »
Thanks Mike, I picked it up at my local paint shop - or at Amazon -
Kitty Hair 868
Best known for their bridging capabilities in rebuilding shattered fiberglass and reinforcing torn or rusted areas of sheet metal, KITTY HAIR® and TIGER HAIR® are formulated with long strands of chopped fiberglass that doubles the strength compared to standard fillers. Waterproof and rustproof. Should be finished with RAGE® and/or METAL GLAZE®. Blue cream hardener included.
L & P  Automotive Paint And Supply 714-777-0250
1261 N. Lakeview Ave. Ste. C
Anaheim, CA 92807
http://www.amazon.com/Fiberglass-Evercoat-FILLER-QT-F-E-PRODUCT/dp/B000ALVW6A
Good catch Tom, yes a bigger washer would work better a trip to a hardware store is on my list.
Old-Towd
Post by Old-Towd »
Needed side mirrors I decided to make my own instead of welded brackets I went with clamp on so they can be adjusted up or down on roll cage -
Trying to keep them tight I countersunk the bolt tubes -
My Buddy Andy did the welding - the convex mirror is a 5 in.  Open Road Truck Mirrors made by Cham-Cal Engineering Co. Garden Grove.  I think I paid under $15 for the mirror, it's USA made.
The clamp bolt tubes were welded in as one piece  to keep bolt alignment, then cut after -
I need to paint and test drive but so far I'm happy with them.
Looks Good Jay.
Manx Club President
Tow'd (Hers)
Ed-Chenal
Post by Ed-Chenal »
Now you'll be able to see what you ran over.....
Old-Towd
Post by Old-Towd »
Thanks manxvair. Your right Ed now I can see what I ran over and keep a eye on your Buggy way back there.
