Sand FIlter Sytem
ovion21
Sand FIlter Sytem
Post by ovion21 »
Hello Everyone,
Can anyone tell me the use of sand filter system and how to install it properly?
https://www.polygroupstore.com/quick-se ... -s/332.htm" onclick="window.open(this.href);return false;
jhkinca
Re: Sand FIlter Sytem
Post by jhkinca »
Do you have a picture, web link, or part number?
I little more info would be helpful.
Thanks,
John & Sonya Kieslich
I know of sand filters for pool cleaning, but not for an automotive air or fuel filter. Are you talking something like an Outerwear air filter cover? Or maybe something like an old school centrifugal air filter?
jhkinca
Post by jhkinca »
We use the old Tri-Phase filters on the Manx and Tow'd. They work great!
5284
jsturtlebuggy
Post by jsturtlebuggy »
CB Performance sells a Sand filter system, It is made to use with Weber IDF and Dellorto style Carbs.
Part #3387
lastmanx
Post by lastmanx »
431943184317 I use the 2 stage k&n sand filter mounted under the rear passenger fender plumbed with new shop-vac plastic hose connected to a stock early air filter with no oil in it, the mesh inside is removed. This in essence creates a sand filtered velocity stack set up. the stock filter has the proper built in height velocity stack. you can also unclip the cover if you need spray carb cleaner or need inspect carb. no tools necessary. you can also connect a crankcase venting hose from the oil fill also a closed system; so no sand enters. more important is the crank pulley sand filter. the press in one is too easy. both have proven effective for 19 years for me. all these tips and more can be found in the hp book how to prep dune buggies.
