there are a number of ways to do everything so this is just the way I did it and it works great for me.
Since I just had our buggy overhauled (http://www.manxclub.com/forum/viewtopic.php?f=65&t=3371) I thought I should
update the system I had in the buggy before. My configuration is the same but the equipment has been updated.
I started looking for a mini amplifier (for a motorcycle) that I could route my cell phone/MP3 player through. I also wanted
Bluetooth so I didn't have to run a wire from the phone/player to the amp. I settled on the Boss Rebel MC470B which came
with four bullet speakers all wired together in a harness. Cost: $125
I mounted two speakers up under the dash/hood and attached to the cross bar using the supplied bar clamps on
the speakers:
Passenger's side:
Driver's side:
Clamps:
I then had to splice in regular speaker wire into the harness in order for the rear speakers to reach the spare
tire well. I cut a small piece of plywood to the contour of the wheel well so the speakers would suspend and not slide.
I also added a couple of pieces of Velcro for additional security. The speakers were mounted upside down and positioned
as far back as I could in the well.
The system works great and you can hear the music (it's not Lincoln Center) well enough.
Just another way to "skin the cat."
