wide 5 drums on ball joint
Where did you get that part or get that work done? If you have a gadget or service to share, please do!
langan
Post by langan »
Can someone post what is needed to convert 4 lug to wide 5 lug drums on ball joint front end?
Ed-Chenal
Re: wide 5 drums on ball joint
Post by Ed-Chenal »
Per Jeff Hibbard's Book......"Baja Bugs and Buggies"
All 66 and 67 five bolt front drums fit 68 or later front brakes and spindles if you use 68 or later inner wheel bearings.
Buy the book on Amazon, it's worth having. http://www.amazon.com/s/ref=nb_sb_noss_ ... nd+buggies
flycut
Post by flycut »
VW Thing 181 Drums are a direct bolt on front and back, Easiest way to convert to wide 5 IMO.
VW Aircooled Society
Contact:
Post by VW Aircooled Society »
flycut wrote:VW Thing 181 Drums are a direct bolt on front and back, Easiest way to convert to wide 5 IMO.
This is a very good tip.. thanks for posting it
____________________
Val Marquez
Miami, FL
Tel: 786-314-2571
Products Manager @ VW Aircooled Society
Innovative Products: http://www.VWAircooledSociety.com" onclick="window.open(this.href);return false;
'64 Manx Classic Dune Buggy
'67 Split Window Bus
'66 Maserati Blue Oceano Bug
'69 Bay Window Weekender Bus
jsturtlebuggy
Post by jsturtlebuggy »
The type 181 (Thing) front drums are the same as used on 1966-67 Beetles ball joint front ends. Both are the wide 5 205mm bolt pattern.
