Ball Joint on Berrien
Gary1719
bumper
Post by Gary1719 »
Thanks Tom for your help. Gary
An original Manx bumper mounts to brackets welded to the shock tower so it will be well out of range of the tow bar or grease zerks.
Gary1719
manx bumper
Post by Gary1719 »
They weld on to something i thought it was the beam it self.well i guess i need to get width and other info i dont want to paint beam find out i will have to grind paint back off.
Post by mel hubbard »
[QUOTE="gary1719;15043"]They weld on to something i thought it was the beam it self.well i guess i need to get width and other info i dont want to paint beam find out i will have to grind paint back off.[/QUOTE] Gary, I found it better to bolt the brackets onto the bar before lining it up for welding, not sure how much the bar widths differ (if any) on each batch made, but it would cut out the guess work by getting the bar first.
manxfwin
Post by manxfwin »
The front bumpers Meyers sold back in '68 and the one they now sell both bolt to brackets that are welded to the lower beam.
Gary1719
bumper
Post by Gary1719 »
`Yeah it would be easier but right now i dont have 300.00 dollars to throw on that. Gary
TMc2548
Post by TMc2548 »
As promised. Sorry it's a bit late. I had technical issues with my laptop. Image Please note that I have an aftermarket replacement beam and my zerk fitting may not be located in the same location as yours. You can see that the bumper mounting bracket is located inside of the bumper and if it were located on the outside it would interfere with the zerk.
Gary1719
bracket
Post by Gary1719 »
Tom thanks for the picture. I'll tell you that looks like it is going to be real close to the brackets that bolt the beam clamps to the front end of the berrien chassis.
TMc2548
Post by TMc2548 »
Happy to help Gary. It's all part of building a buggy. One step at a time. Solve one problem and another comes up. Keep at it and sooner or later it'll be finished. Really.
