More Rear Swing Axle Woes!!!!!!!
Upcoming events and get-togethers. Where are we going next?
Jon
Post by Jon »
OK Here's the next problem for the forum.... I've got about and inch of end play on the drivers side axle. Is this normal? I can grip the splines at the axle end and push and pull the axle in and out....
That is normal. Once you install all the pieces and tighten the nut to the specified torque the play will be gone.
L0084MC
Post by L0084MC »
I agree. I had the same problem not long ago with the same worry. I also was straightened out on this forum. after everything was installed and tight it was fine.
Jon
Many Thanks
Post by Jon »
This forum is really great thanks for the responses!! I thought I installed the axles in the tranny wrong.....
Typically if the axles don't move in and out before the drums are tightened up you have a problem, usually one of the fulcrum plates slips in between the end of the axle and the axle side gear. Something to keep in mind next time you have the axles out.
