Wing mounting hardware
Artie8804
Post by Artie8804 »
Does anyone have any pictures of the wing mounting hardware as it mounts to the body? Im trying to fabricate my radiator mount but need to get the wing in place. Thanks in advance.
1MINT86
Re: Wing mounting hardware
Post by 1MINT86 »
Hello Artie,
I recently just completed mounting the radiator on our Dual sport 025. I first mounted the wing and then made the radiator mounts fit the wing angle. The top of the wing hinges off the body and I made some brackets to mount the sides. Are you using the Ron Davis radiator he makes for the Manxter ?
2989
2988
2990
Hope that helps.
Artie8804
Post by Artie8804 »
Thank you for the reply. The rod Davis radiator was way to expensive. I picked up another radiator with the same dimensions that I will have to modify to have the filler neck in the right location. So the aluminum color bracket is the one that you created?
1MINT86
Post by 1MINT86 »
This is a picture of the radiator mount without the radiator installed and another with the top mount a little more visible.
2996
2987
I think the aluminum colored bracket you are referring too is the side of the radiator.
Greg
jsturtlebuggy
Post by jsturtlebuggy »
On my wing mounting to the body I used reversed stainless steel hinges from West Marine. They are kind of like the ones used on the airbox for a Manxter.
To hold wing to body I using the draw latches that are the same one for the front hood.
I also used L brackets from bumper cage to lower inside corners of body. Another thing I did was made up struts using stainless rods and heim joints to hold up wing. This was something I saw on Mark Miller Dual Sport Manxter. It also make a great way to level wing too.
30043005300930033002300930083007
jsturtlebuggy
Artie, I figured out how to post pictures in my gallery and link them to this post.
Artie8804
Post by Artie8804 »
Ok I figured out the way I will mount everything. One last question is, can anyone provide me with the angle their radiator ( or supports) sit at? This is a reference angle. I will fine tune it once I mount the wing to the body. Thank you.
1MINT86
Post by 1MINT86 »
Hi Artie,
I measured mine tonight and with the chassis level the radiator angle is approx. 19 degrees.
Greg
Artie8804
Post by Artie8804 »
Great. Thank you so much.
Artie8804
Post by Artie8804 »
Another question. What are you folks out there using as rubber isolators for radiator mounting?
jsturtlebuggy
I am using 1/4in thick wetsuit material for the expansion and cushion. I found the material at a surplus store many years ago. It has held up well since installing the radiator. The Ron Davis radiator expands more side to side then top to bottom.
Artie8804
Post by Artie8804 »
Awesome. Thanks for the food for thought.
Artie8804
Post by Artie8804 »
Created this file for my radiator mount. Will sit inside the wing and attach to the rear metal work. Being cut out of 1/8" mild steel and dimple died for strength.
Artie8804
Post by Artie8804 »
All cut out and ready to bend and dimple die.
Post by manxvair »
Those look great! keep posting on your progress as I'm quite a way from the radiator stage though.
Manx Club President
Tow'd (Hers)
