Tow'd U bolts and tow bar, ISO
Posted: Wed Feb 25, 2015 2:14 am
by pongo
In search of new long U bolts for the Tow'd. If you've replaced them, where did you get them?
Also in search of a Tow'd tow bar. Looking for a source to purchase a coupler, in the style originally used. Or, if anyone has a bar laying around their garage, and would like to sell it.
Paul
Re: Tow'd U bolts and tow bar, ISO
Posted: Wed Feb 25, 2015 2:50 am
by manxvair
I got Lori Ann's Tow'd bar from Turn Key Manx, The web page still list's them. I went looking for our old bolts but I haven't found them yet.
Posted: Wed Feb 25, 2015 3:59 am
by pongo
Thanks Mike, I saw the bars listed on TurnKey, listed, "not in stock", I emailed couple weeks ago, no reply. I figured, it wouldn't hurt to ask around. I think I can reuse my U bolts, but would replace them, if they're readily available.
Posted: Wed Feb 25, 2015 4:33 am
by manxvair
I think Brad has been in Australia the last couple of weeks, might explain not responding I'll try to reach him.
If you can find a suspension shop they might be able to make you new U bolts, I had one out here make 1/2" to replace the 3/8" ones that we had.
Posted: Wed Feb 25, 2015 5:18 am
by pongo
I will try to find a suspension shop.
Figured he would get back to me when he was available.
thanks Mike
Posted: Wed Feb 25, 2015 6:09 am
by manxter36
You might be able to find some u bolts designed for 4x4 or trucks. I've also remember someone using allthreads.
Here is link with some info
http://rbcdunebuggy.yuku.com/topic/2309 ... rts-needed
I made a tow bar out of 2 1/4 od thick wall tube that's 42 inch long if I remember correctly. I then welded and bolted on a standard hitch as I couldn't find one that looked like the one Bruce used.
Unfortunately it doesn't retract all the way the originals do.
http://rbcdunebuggy.yuku.com/reply/1483 ... eply-14830
Doran
Posted: Wed Feb 25, 2015 9:46 pm
by pongo
thanks Doran, I've check out the links.
For the long u-bolts, I located a company in NY, and have submitted the original dimensions to request a per unit price and minimum number per order.
Posted: Thu Feb 26, 2015 6:01 pm
by vwmanx
Paul,
I made a spare set for my Towd from Stainless Rod and threaded the ends.
They are pretty straight forward if youcannot get them made.
