Guys, I have a link pin beam I intend to use on my new project. Problem is, one of the brake drums is frozen. The beam is not on a car so I cant drag it free (my usual method). I have removed the bearing nut and have been tapping ( beating the s#&t out of it) for 2 days. I have also tried soaking it in WD-40. This sucker just wont move. I cant turn it at all and it wont come off. Any suggestions? I dont care if the drum is ruined as long as I get it off the beam. Thanks, Scott
Drill out the brake shoe hold down pins from the back of the backing plate. The reason it won't come off is because the shoes are stuck to the drum, by drilling the hold downs it will allow the shoes to come off with the drum.
Thanks Jerry. That sounds like a viable idea. I'll try it tomorrow. Cant adjust the brakes in because in VW's the adjustmet hole is in the drum and I cant turn it. I can see this is going to be challenging. All the parts I am using except for the pan, engine and tranny have been sitting somewhere in the weather for atleast 20 years... Combination of atleast 6 cars...
[QUOTE="Reverb"]Even if you drill the retainers, wouldn`t the adjuster, and the wheel cylinder still hold the shoes from coming out?[/QUOTE] I dont think so. But the springs would still give some resistance. If I get that far I will get the drum off.
[QUOTE="WuZaBuG"] Cant adjust the brakes in because in VW's the adjustmet hole is in the drum and I cant turn it. [/QUOTE] Whoops, I messed that up. I was thinking late model.
Even if you drill the retainers, wouldn`t the adjuster, and the wheel cylinder still hold the shoes from coming out? In theory the shoes should kind of "fold" into each other as the drum is pulled off. Another reason it might be froze is the wheel bearings could be frozen solid and the drum could be locked to the spindle. just a thought
