Front beam bolts to head?
What is the diameter of the bolts that hold the fromt beam on to the head? I want to thru bolt with lock nuts on the other side and need to know diameter to buy them tomorow!
i think i used half inch by 6 inch grade 8 bolts with lock nuts
Did you have to drill the threads out in the head to thru bolt with the 1/2 inch bolt? The original bolts are metric and a 1/2 inch stantard wont thread...
Reverb
Post by Reverb »
If you have a hardware store near by, take one of the original bolts with you, find a metric nut that fits it.
TMc2548
Post by TMc2548 »
I think its a 12mm x 1.5 thread bolt. Not too sure. Its been awhile since I tapped out the head.
Ok I want to replace them with stardard thread/diameter stainless steel bolts. What would be the equivalent to 12mm in inches? That way I can buy a drill bit to knock out the threads in the head and thru bolt with the S/S bolts and lock nuts.
yes i drilled them thruogh
1/2 inch = 12.5mm From my old dual dimensioning days. Wild Mike
So then a 1/2 inch drill bit will actualy make the hole a tiny bit larger (.5mm) and knock off the threads as well? Then Ill just use a 1/2 bolt right?
OK ... I was a little off. The 1/2" is actually 12.7mm ... hey it was over 20 years ago. If you're going to use a 1/2" bolt then you will need to drill it over size. You need to use at least a 9/16" drill. The site I just checked said 15%-20% larger hole than the bolt size. Wild Mike
Why would I want a larger hole than the bolt itself? Any particular reason? I have drilled 1/2 inch holes before and used a 1/2 bolt with no prob...then why?
Alex DON'T use stainless. Most stainless is very brittle and only rated to grade 3. MURZ
Then how do I get a clean look ? Titanium jaja kidding! Will have to go with galvanized then...
I used phosphate coated iridium. Looks slick!!!! Strong too!!!! HEHEHE
And u thru bolted with a lock nut on the other side? Where do you get those bolts from? Local hardware store? Havent seen them.....
