However, the mystery I mentioned isn't just where PCS 076 is now, the mystery is why did PCS 076 change from a gold metalflake monocoque into a red first generation floorpan Manx 1? Its possible PCS 076 may have been in an accident and its registration and plates may have been used on the new red Manx 1. Something else I notice that may have been recycled are the knock off nut hub covers which appear to be on a gold metalflake first gen Manx 1 which I suspect is SLW 511. Ironically SLW 511 which was both the Car and Driver and Road Test cover car and was also Bruce's racer in the first Baja 1000, was later cannibalized as the chassis of the first Manx SR.
Then this happened! PCS 076 changed from a gold metalflake monocoque into a red early floorpan (square tail) Manx. The gold metalflake Manx in the picture is Bruce's personal Manx, SLW 511, and its gained a set of knock off nuts like PCS 076 used to have
